Oil leak on back side, rear, of motor
Old 01-13-2014, 10:15 PM
SanAntonio Joe's Avatar
So my wife's '06 HHR 2LT with a 2.4, and 120,000 miles is developing a slow but steady oil leak on the back side of the motor, and it is leaking down right where the motor mounts to the transmission.
At first, and after reading many of the posts, I thought it was the oil pressure sending unit. But, that is on the front side of the engine, and that side of the engine is spotless; not even a hint of any oil seepage. The back side is clean also under the valve cover gasket, which I replaced several months ago. I have also done the sensors on the top of the head.
So, any ideas what this could be other than the seam where the halves of the block are mounted together?
Thanks!
Joe
SanAntonio Joe is offline
Old 01-14-2014, 07:20 AM
Check the TSB thread. Your car may be covered under the one about a bolt hole that was drilled too deep. Sorry, my internet connection is too slow right now for me to use the SEARCH box for you. (just a fact,not a snipe)
Old 01-14-2014, 10:01 AM
I found EI08224; that doesn't cover 2006 models and the leak seems to be around the back of the engine, not the front. Will keep looking at the engine, as well as monitoring this thread.
Thanks,
Joe
Gator
04-21-2016 07:21 AM
SteveMaine
05-25-2013 10:46 AM
HHRizoid
05-28-2012 10:29 AM
brett
09-25-2007 11:26 AM
Quick Reply: Oil leak on back side, rear, of motor
