Intermittent Power Steering & have already replaced Power Steering Motor
Old 09-05-2013, 11:07 AM
brazor06's Avatar
Exclamation Intermittent Power Steering & have already replaced Power Steering Motor
Ok, I have had my '06 hhr for about three and a half years now. I have had recently now a problem with my power steering going out and then coming back, also with the light on the dash comes on/off, and sometimes the security light comes on as well, and once that is on that will not go off until we shut off the vehicle and then restart. I have already had my husband replace my power steering motor and that did not solve the problem, we already replaced a relay under the hood as well. I am at such a lost, that I am about to take it to the dealer and spend the $100.00 for the diagnostic test just to see if something comes up on the Tech II.
brazor06 is offline
Old 12-10-2022, 06:28 PM
adrew1996's Avatar
What fixed the issues with your power steering issue?
adrew1996 is offline
Old 12-10-2022, 06:34 PM
This thread died in 2013, the OP has never returned.
Old 12-10-2022, 06:58 PM
Most likely the extended replacement from GM
Old 12-10-2022, 08:23 PM
RJ_RS_SS_350's Avatar
Another 1 and done...
RJ_RS_SS_350 is offline
Old 12-11-2022, 07:59 AM
We can only guess. So, I’ll close this
le2007will
12-11-2016 07:17 AM
SteveMaine
12-18-2015 11:01 AM
07azhhr
03-30-2014 02:57 AM
Sundance
02-16-2014 08:53 AM
Quick Reply: Intermittent Power Steering & have already replaced Power Steering Motor
