Remote Start Battery
Old 08-08-2006, 09:31 AM
glenngeb's Avatar
Thumbs up Remote Start Battery
Has anyone had to replace the battery in their remote start yet? If so where do you get the batteries
Thanks
Glenn
glenngeb is offline
Old 08-08-2006, 09:37 AM
captain howdy's Avatar
Do you mean the key fob battery? Look on the back of the key fob, the battery is a CR2032. You can buy them pretty much anywhere that sells watch batteries. Try your local drug store, convience store, grocery store, or places like Walmart and Target.
captain howdy is offline
Old 08-08-2006, 10:49 AM
JESSE's Avatar
Is just changing the battery enough? Does it need to be reprogramed?
JESSE is offline
Old 08-08-2006, 10:56 AM
courthousedeb's Avatar
I just checked the owners manual and it doesn't mention anything about reprogramming, so I would presume it's plug and play of sorts. It also says the battery should last 4 years too....but I would think that would depend on how often it's used.
courthousedeb is offline
Old 08-08-2006, 01:31 PM
cj krause's Avatar
take apart fob
take out battery
put in new battery
push fob together
point at car
push button needed
LOL,,, had to say that
i use a pearing knife which has a very thin blade to get it apart. slide the edge in and pry carefully with the sharp edge of the blade
pry the back off so where the back is up and it just pops off.
slide battery out and change it
with the back up, lay in the cradle where it came from, ease back down and then push till sealed
cj krause is offline
Old 08-08-2006, 02:04 PM
glenngeb's Avatar
Thanks guts I have passed on this info. This forum is excellent. Full of useful info and speedy responses
glenngeb is offline
Old 08-08-2006, 02:07 PM
glenngeb's Avatar
Thanks to all. I have passed on the info to another proud owner of an 2LT. I have also become a member. There is so much excellent info on this site and the response time is super.
Thanks again
glenngeb is offline
HillsdaleHHR
02-21-2009 02:26 PM
JJ_HHR
10-10-2008 04:45 PM
Joseph E. McKie
07-30-2008 02:57 PM
adamlowery
11-18-2005 02:04 PM
Quick Reply: Remote Start Battery
