Bolt pattern for wheels
Old 01-10-2011, 07:52 PM
kenh1's Avatar
Is the bolt pattern for an 06 the same as the 09? 5 X 110?
kenh1 is offline
Old 01-10-2011, 07:54 PM
Yes it is.
Old 01-14-2011, 11:57 AM
bartSS's Avatar
with a 40mm offset
bartSS is offline
Old 01-14-2011, 12:59 PM
LawDog88's Avatar
Can someone explain what an offset is? I've not understood that
LawDog88 is offline
Old 01-14-2011, 01:09 PM
Wheel offset is the amount the center of the wheel is offset from the center line of the wheel, this picture will help explain it. Front wheel drive vehicles have the wheel centers offset to the outside of the wheel(positive offset), rear drive vehicles have it usually centered(zero offset) or offset to the rear of the wheel(negative offset).
Old 01-14-2011, 02:42 PM
LawDog88's Avatar
Thank you 843
LawDog88 is offline
Old 01-14-2011, 03:23 PM
And.............. That picture should explain exactly why RWD wheels can't be used on FWD cars....... No matter how cool deep dish wheels would look on an HHR.
Greybeard999 is offline
Old 01-20-2011, 04:07 PM
LewiSS's Avatar
But note that offset is measured from the center of the wheel. Therefore, a wider wheel will have more "dish" than a more narrow wheel with identical offset (and the amount of the additional dish will be half the amount of the difference in width between the two wheels). Also, a wheel like the Wheel Vintiques looks "deeper" than a cast wheel for a couple of reasons beyond width. One, the thickness of the wheel center is less on a steel wheel than on a cast wheel - thus the distance from the plane of the outer rim to the face of the wheel is more (because the face of the wheel is considerably thinner). Second, Wheel Vintiques did a great job of "reverse dishing" the center so that it connects to the outer rim deeper in the wheel than on a cast wheel (again, being steel this is easier to do because all the thicknesses are less). This gives you more rim sticking out from where the center connects, thus giving a deeper look visually. So the Wheel Vintiques Smoothie and Rallye both appear to be more of a "chrome reverse" style than about any other wheel on the market for our cars, thus giving you more of that vintage deep dish look.
Now, is anyone interested in buying 4 absolutely perfect stock SS wheels/tires with 5K miles on them in the Denver metro area so I can go buy me a set of Chrome Rallye wheels and baby moons?
LewiSS is offline
Old 01-24-2011, 05:57 PM
john whalen's Avatar
rims (cheap)
im looking for four rims that will fit on my 07 hhr lt that i will put snows on and what are the reasonable best snows, also then i'll need some touring s that give me good mileage and stability mostly hi-way in both areas of driving i'm thinking of going to 15 inch for the snows i have 16 inch now for summer
john whalen is offline
Old 01-25-2011, 03:39 AM
LawDog88's Avatar
Welcome John. Blizzaks are good from what I hear. Also, I recommend a set of 16" steel rims that come on the LS. They are just gloss/matte black color. Some people here are trying to sell theirs. Fair warning. From a dealer, they are about $130-145 per rims.
LawDog88 is offline
Quick Reply: Bolt pattern for wheels
