P1174
Old 12-03-2010, 02:59 PM
1970judge's Avatar
P1174
I did a search an no one has come up with a solution. My car is throwing this code intermittently. Came on for a day, went away later that night, threw it a few days later(today) and still on.
Fuel balance.
Any ideas yet?
1970judge is offline
Old 12-03-2010, 03:15 PM
Fuel trim and cylinder balance....hmmmm.....bad injector(s)?
Old 12-03-2010, 04:33 PM
Zagohhr's Avatar
Definitivelly is a bad injector. I had struggling about 6 month with this code. I changed spark plugs, added tons of fuel additives, swaped coils...nothing. I just replaced the 2nd and 3rd injectors, and this rid the code.
Zagohhr is offline
Old 12-03-2010, 04:49 PM
Dirty injector will throw the same code and this TSB states to replace all injectors and reprogram ECM.
https://www.chevyhhr.net/forums/problems-service-repairs-42/official-tsb-recall-thread-23231/#post377970
Old 12-03-2010, 07:06 PM
1970judge's Avatar
Originally Posted by ChevyMgr
Dirty injector will through the same code and this TSB states to replace all injectors and reprogram ECM.
https://www.chevyhhr.net/forums/showthread.php?p=377970
Thanks! Deal with the light it is!
Old 12-03-2010, 10:02 PM
dandhcomputers's Avatar
sorry to hear that 1970judge .I hope you can get that fixed soon...
dandhcomputers is offline
Old 12-03-2010, 11:47 PM
1970judge's Avatar
I haven't noticed any lean pop under hard acceleration yet.
Old 12-28-2010, 03:45 PM
1970judge's Avatar
Well it's been almost a month since this happened, and after finishing off that particular tank of gas (walmart), running some proven cleaner through it, and filling back up with shell gasoline...no code.
Old 03-22-2011, 06:58 PM
1970judge's Avatar
Came back today, for the first time since December. It threw the P1174, and a misfire code on cylinder 2. Looks like injector two may be failing. It is smoking a little on cold start up as well, white smoke that smells like pure gasoline. Going through a rough couple of weeks here lately.
Old 03-22-2011, 07:05 PM
Spozo's Avatar
Year, and engine would be nice to know...
Spozo is offline
Quick Reply: P1174
