Snow Tire Performance
Old 12-26-2007, 01:19 PM
froggy22's Avatar
Same here rain and small storm we had in NYC no traction at all! Coming fronm a yukon its hard
froggy22 is offline
Old 12-27-2007, 06:46 PM
Hib Halverson's Avatar
Originally Posted by Dan's HHR
yesterday in Quebec we've got a MAJOR snowstorm(1 1/2 feet) and i have to admit that the stock firestone runs very well in the heavy snow, sure winter tires are the best i couldn't denied that but i was really amazed with my stock tires.
If you're "amazed" at the stock tires in snow/ice conditions, then you'll be flat astonished at how your HHR drives with a set of high-end winter tires, such as Bridgestone's "Blizzak" brand.
I have compared other brands of winter tires on a snow and ice covered test track and found Bridgestones to be marginally better and way better than ordinary tires with mud/snow-rated treads.
Hib Halverson is offline
Old 03-03-2008, 05:29 PM
novadude's Avatar
Snow TIre Performance
All...
I feel the need to remind you to read you owners manual...
[B]Snow chains are not an option[B]
Not enough wheel clearance with the stock 17inch
I have an 07 2LT, 2.4 Auto, all stock ..
I live in central Ca,, so wont see snow much,,
although I am driving to Reno this coming weekend and that
requires driving up to 6800 ft elevation over Donner Pass,,,
novadude is offline
Old 10-03-2009, 05:05 PM
Seattle Panel's Avatar
Tire Chains!
Originally Posted by novadude
All...
I often drive in very bad snow conditions-skiing in the northwest-across to Idaho-passes etc.
this is my first winter with my HHR.
As for CHAINS------you can NOT put chains on an HHR? Chains are often required by law enforcement on the passes!
And-does this include/mean the small cable chains? I sure hope they will work-they make your car into a tank in bad conditions!
I appreciate any replies to this issue!
SP
Seattle Panel is offline
Old 10-03-2009, 05:34 PM
From reading more-I understand that the reason for the chains not working is from the strut/business side of the tires.
Would these thule chains work? Again-I want to reiterate that occasionally on mountain passes the state patrol REQUIRES chains-and is more than happy to pull everyone over without them.
Here is a link to the thules...they only mount to the outside of your tire-
http://www.autoanything.com/driving-...A4339A0A0.aspx
Allen S
Tires & Wheels
02-10-2014 04:50 PM
steveshow
2.0L Performance Tech
15
06-16-2010 01:38 PM
cheroke75
Tires & Wheels
08-01-2007 08:28 PM
Quick Reply: Snow Tire Performance
